1994 Chrysler LHS - No Start When Eng Warm FIXED
autoxperts
Post by autoxperts »
Runs and drives great, no codes, after shutting off the ignition it will not start and has no spark. new coil, new fuel pump, new computer,
Re: 1994 Chrysler LHS - No Start When Eng Warm
Is there RPM reading on the scanner when cranking during the symptom? Scope the crank sensor during warm restart.
Re: 94 Chrysler LHS - No Start When Eng Warm
1994 Chrysler LHS - No Start When Eng Warm; perfect advise
agreed, sensor is temp sensitive and since it's really only used during initial start up it can fail during a drive cycle and if the engine isn't shut off it will never be needed again. a little foggy here but isn't there a second sensor that is a balancing one that should be replaced as well. i'm thinking that they're both fitted to read the fly wheel. could be wrong but i've got that "i remember one that really messed with me" feeling. it was a chrysler and i think i had to replace two sensors to solve this issue.
fortknoxx
Post by fortknoxx »
check to see if the starter is getting the signal to start before you go replacing sensors. it might be the starter heating up and not wanting to work. remember the sb chevys with headers and no starter wrap?
zipsauto
Post by zipsauto »
If i remember correctly, a faulty camshaft position sensor would cause this issue.
autoxperts
crank sensor fixed problem . thanks for all the help.
fortknoxx
Post by fortknoxx »
i think i speak for all, thanx for posting the fix
Re: 1994 Chrysler LHS - No Start When Eng Warm FIXED
a posted fix, the skies are parting and i think i hear trumpets......... :D :D a good way to start the day.
Return to “Dodge Cars”
