2005 Dodge Neon - Camshaft Sensor Code
Princeton Auto
Post by Princeton Auto »
I thought for sure there would have been a post about this.
2005 Neon with the Camshaft Sensor code present. The customer has replaced the camshaft sensor twice in the last 25K miles. (different shop) I see these failures regularly but not this consistant. Has anyone found a good reason for the failures or is it the poor sensor quality?
Michael
Princeton Auto Service Center
nickscarcare
Re: Camshaft Sensor Code--Neon
Post by nickscarcare »
OEM sensors only!!!!! Check wiring and connectors to cam sensor and to crank sensor. If I remember correctly a bad crank sensor could cause the issue also.
Princeton Auto
Thanks. I always do check all connections. I'll try that and see what happens.
Michael
I own 3 Neons as loaner cars. One of mine was always throwing a cam sensor code. Turned out the timing belt was off one tooth.
Absolutely OEM sensors only! Usually if there is a code coming up, there is another issue. Connectors have been a source of frustration. So I have replaced many of them as well. And there again, only OEM wiring pigtails.
ricmorin wrote:I own 3 Neons.
Gluten for punishment? :lol:
I've heard you talk about loaners and sometime soon I'm going to PM you with some questions if you don't mind.
Ruger77
Re: 2005 Dodge Neon - Camshaft Sensor Code
Post by Ruger77 »
If you guys ever get into a conversation about the loaner car thing, please post it as a topic. I think a lot of people would benefit from the conversation, including me.
Scott
Return to “Dodge Cars”
