Transmission light come on, in the dash. After a little bit of driving, there is a beeping noise. Nothing in a set pattern - very random. Dash lights will flicker.
No codes present.Checked transmission fluid & test drove, watching data on scantool - nothing seems out of the ordinary.With the no code situation, felt there was a fault in the instrument cluster. Replaced with a rebuilt from Ford. Still has the same problem.
Any ideas??
We have tried Identifix, iAtn, and our local transmission rebuilder. No one else has seen this problem before.
