2000 Ford Taurus - Fuel Gauge Reading FIXED
AFFORDABLEAUTOREPAIR
Post by AFFORDABLEAUTOREPAIR »
2000 FORD TAURUS SE - VIN 2 FLEX FUEL
FUEL GAUGE READS FULL ALL THE TIME; SCANNER SAY 100% AND 5 VOLTS, TANK HAS ABOUT 3 GAL OF GAS. CHANGE SENDER AND GAUGE IN DASH, WHAT AM I MISSING?
THANKS DAVE
bakerauto
Re: 2000 FORD TARAUS
Post by bakerauto »
Flex fuel module---located above gas pedal under steering wheel (little black box) Hope this helps
Re: 2000 Ford Taurus - Fuel Gauge
Did you sweep the gauge?
THANKS FOR THE INPUT FUEL MOD REPAIRED OUR PROBLEM. FORD SELLS ALOT OF THESE TECHS SAY FLOATING OR INACCURATE READINGS REPLACE MOD. PART #YF1Z-14A069-AA. THANKS AGAING FOR YOUR HELP DAVE
Re: 2000 Ford Taurus - Fuel Gauge Reading FIXED
a real quickey here. as a rule (in my shop) i can count on one hand how many ford modules i replace in a year and fill a 55 gallon trash can with the g.m.'s. on a ford i will replace the gauge assembly if it's available from ford or dorman. dorman has really expanded it's coverage.
Return to “Ford Cars”
