2002 BMW X5 Factory DLC Location
nickscarcare
Post by nickscarcare »
I have a 2002 X5 here that I am trying to locate the factory 20 pin DLC connector. Mitchell is behind on this because they give a generic description, and the BMW's they do list they don't have a X5. Vehicle is 10 years old and lack of info. I can find the OBD connector, but not the factory connector. The VIN is 5UXFB33562LH35730. 4.4L
Re: 2002 BMW X5 Factory DLC Location
I have a picture that shows the round connector tucked in behind the OBD connector.
nickscarcare
Identifix says underhood, LF strut tower, not there. It is not located by the OBD2 connector. Someone told me they may have gone away with it? I was hoping to catch a BMW expert on here that could say, Yep its right there!
I'm no help; I turn away almost all BMWs cause I don't like them.
I also see the connector behind the obd2.
nickscarcare
Well I even dropped the panel, and it is not there. Guess there are no BMW gurus out there to help. Unless this one don't have it. Guess I will have to just use the global port. :? Identifix shows it under the hood, but its not there either.
Thats why i avoid these things. all that work for free sucks. and ususally they expect u to be less then the dealer lol
zipsauto
Post by zipsauto »
Most of the post 2000 model BMW's only have the DLC-16 OBDII diagnostic connector.
liljoe
Post by liljoe »
I use the OBD2 port with my auto enginuity scanner and acess all modules on the Beemers..... Do not remember seeing the older style connector on the one of these that I have had in here, but it was an 01 so not sure about the 02, but would think it would be the same....
nickscarcare
Yes I am guessing no 20 pin connector. I got the obd2 port to work, but since I have the capability and the cables, I always try to use that port. Thanks for the replies.
Return to “Imports - Other”
