I have a 2001 eclipse with 2.4 sohc engine. brought in with no start. Has new timing belt and new cam sensor. i check and has no compression on a few cylinders. So I remove cylinder head have bent valves replace, head milled ( I backed the head bolts out with 3/8 ratchet with no problem or strain). I put cyl head back on with new head bolts and proper torque procedure, install timing belt all gears in time go to start the engine and it starts to kick back like it is out of time while busting the nose off of new starter the customer just had put on before bringing to me. I go and put another starter on and still no start and it drags and kicks back like it is out of time. According to all information that I have found it seems to be in correct time. Used the ole screwdriver in cyl #1 and turned it by hand everything looks right. Any suggestions???
After consulting with the DIY customer, I found that after removing the crank gear and reluctor (tone) wheel and reinstalling the customer had damaged the reluctor just enough to throw off the signal. Taking no more chances and wasting no more time, I replaced the reluctor plate and the crank sensor.
Fired right up like it should and purred like a kitty.
It looks like when the DIY customers fail at a repair they are just to ashammed to let the tech know all that they #*$! up. It would make the job alittle easier to bare. Thanks to all.
