2007 Mercedes CL550 - Maintenance Reset
Maintenance reset? Tech support sent me a procedure but it is not correct it says to turn the key to position 1 and its a push button starter? second it says to go to assyst plus workshop by holding the phone p/u and ok buttons down which doesnt work? So im lost
Re: 2007 mercedes CL550
I have some info if you want me to fax it to you.brianp87 wrote:Maintenance reset? Tech support sent me a procedure but it is not correct it says to turn the key to position 1 and its a push button starter? second it says to go to assyst plus workshop by holding the phone p/u and ok buttons down which doesnt work? So im lost
No problem. On the keyless, position 1 is a single push of the button with the brake off. Sending.......
Awesome ric i think the key was the # one position i had the other info just no that
Glad all is well.
