1998 BMW 328i - 2.8L Codes
Posted: Wed Apr 14, 2010 2:54 pm
by AFFORDABLEAUTOREPAIR
WE NEED HELP WE JUST INSTALLED A USED ENG.. THE OLD ENG HAD BLOWN HEAD GASKETS AND NO RUN. NOW WE KEEP GETTING 202 O2 BK1 CONTROL LIMIT, 203 O2 BK 2 CONTROL LIMIT, 227 MIXTURE DEVIATION CYL 1-3, 228 MIXTURE DEVIATION CYL. 4-6, 65 CAM POSITION SENSOR. WE REPLACED WITH SENSORS ONES OFF OLD ENG. SAME CODES, TOOK OFF OF A RUNNING CAR SAME CODES. ANY SUGGESTIONS WOULD BE HELPFUL. THANKS DAVE
Re: 98 BMW 328I 2.8
Posted: Wed Apr 14, 2010 3:24 pm
Ive never worked on a bmw ever but I would be checking the harness for a short to ground. Are those codes P0--?
Re: 1998 BMW 328i - 2.8L Codes
Posted: Thu Apr 15, 2010 8:33 am
TRANSPOSED BMW CODES TO P0 CODES AND THEY ARE P0171, P0173, P1188, P1189, WE CLEARED AND COME RIGHT BACK CKECKED ALL WIRING . SENSOR 2 STAYS THE SAME ON LAB SCOPE EXCEPT WORKING THROTTLE THEN CANGES SEN 1 HAS CONSTANT MOVEMENT. REPLACED SENSOR SAME PROBLEM.
Posted: Thu Apr 15, 2010 8:43 am
by fortknoxx
was the jy engine out of same ymme car?? you might need the pcm out of donor car
Posted: Thu Apr 15, 2010 9:53 am
NOT FOR SURE ABOUT ENG. BUT WHEN FIRST INSTALL RUN LIKE CRAP; SWAPPED INTAKE AND ALL SENSORS. RUNS GREAT NOW.
Posted: Thu Apr 15, 2010 11:30 am
OK CHANGED MASS AIR AND NOW WE ONLY GET BACK CODES 202 (P0170), AND 203 (P0173) ARE THESE FRONT OR REAR O2?
Posted: Sun Apr 18, 2010 3:08 am
rule of thumb in my shop is when we repair or replace do to head gaskets we replace 02's. we all know they've been hit or maybe a front on a head that didn't push coolant is ok but if it's isolated to just one we replace all. if the customer refuses to agree to replacing the lone soldier i'll just do it, tell them i cracked it somehow and spread my cost around in the parts. it's just a prudent move. i know that if i didn't replace it,it would pop a code the next day. in this case you stated both heads are cracked, we know that all 02's got hit with coolant. don't use off shore universal ones please. i believe there are 02 manufacturers that will claim the only difference is the length of the lead. not true....................
Posted: Mon Apr 19, 2010 8:59 am
by fortknoxx
bosch
Posted: Mon Apr 19, 2010 3:52 pm
by protraxrptr17
steven kiser wrote:rule of thumb in my shop is when we repair or replace do to head gaskets we replace 02's. we all know they've been hit or maybe a front on a head that didn't push coolant is ok but if it's isolated to just one we replace all. if the customer refuses to agree to replacing the lone soldier i'll just do it, tell them i cracked it somehow and spread my cost around in the parts. it's just a prudent move. i know that if i didn't replace it,it would pop a code the next day. in this case you stated both heads are cracked, we know that all 02's got hit with coolant. don't use off shore universal ones please. i believe there are 02 manufacturers that will claim the only difference is the length of the lead. not true....................
I'm slowly learning all the things you said in that post. :(
On these cars, replace the VANOS seals anytime you have it apart or are working on a drivability complaint. There's a guy that sells a kit for it. Google it and you will find him. If you do this, the owner will love you and you will save yourself much heartache.
Posted: Wed Apr 21, 2010 1:58 am
fortknoxx wrote:bosch
amen to that but i must add, bosch direct fit oem. i lol at a sales man that tried to tell me that cutting and splicing the connector from the old 02 to the oem direct fit universal was just fine. i asked him if it was acceptable to extend the harness with trailer wire because it was color coded. he thought that it would be just fine. man, i was dumfounded. abominations like this end up in our shops and stuff hits the floor like hair in a barber shop.
Posted: Wed Apr 21, 2010 3:09 pm
by protraxrptr17
May I ask why it is not good to extend the wires? Not doubting you, just wanting to know? I wouldn't use crimp on splices, but actual solder and heat shrink. I have never done this (I always get direct replacements), but if in a pinch, why not?
Posted: Thu Apr 22, 2010 12:07 pm
i've always worked with the more splices, length, wire guage, effects the integrity.
Posted: Wed Apr 28, 2010 6:53 am
by fortknoxx
adding lenght to your o2 harness adds resistance (ohms) and could chande your readings during testing.
