2002 Mitsubishi Spyder - Evap Drain FIXED
Stewart Levy
Post by Stewart Levy »
Looking all over for the drain for this evap case Anyone know where it comes out of the floor boards are full both side front. No luck ! No Figures! No Nothin!
TK Stew
Re: 02 Mitsi spyder evaporator Drain
REFER TO TSB 04-55-008
it refers to removing cabin air filter or installing one and cleaning from inside box.
I haven't found a good pic. Found the TSB that Steve refers to. The last one I found was weird. I looked all over the firewall and cowl...nothing. So I pulled a few panels off the center console and found the rubber tube. Apparently it exited between a double panel on the firewall and there was no way you could see it or access it. Look under the dash and you might find it. I pulled mine off and blew it out from the inside...full of debris because someone mis-install a cabin filter.
Sorry I couldn't be more helpful.
Stewart Levy
Fixed :D
Found Drain by drivers side of firewall. Low and hiden by subframe. Used suction gun to pull the trash out of it flows like I did when the beer was flowing. Filled up a gallon pail.
Re: 2002 Mitsubishi Spyder - Evap Drain
thanks for posting fix. when i have a car with a plugged vent or just one with a musty smell i replace the cabin air filter and if the customer isn't sensitive to odors i'll spray it with a light amount of fabreeze.
Return to “Imports - Other”
