I have 03 hyundai sonata 2.7 that is hard to start only after refueling. It did set a code of P1167.
Has anyone had this before?
Thanks Tony
2003 Hyundai Sonata - 2.7L Hard To Start
Re: 03 HYUNDAI SONATA HARD TO START
I had a 2000 Sonata towed in for intermittent no start. Customer had fuel pump replaced at another shop. Test found power and good grounds to connector at top of tank. Figured got a bad pump on prior repair. Removed pump assembly, found connector at hanger on tank side overheated, causing intermittent no start. Repaced hanger assy and sub harness, no more problems. Local dealer had the parts in stock. Kinda indicates a regular problem, they sell enough of them to keep em in stock. HTH. Jeff.
