2002 BMW X5 Factory DLC Location
- nickscarcare
I have a 2002 X5 here that I am trying to locate the factory 20 pin DLC connector. Mitchell is behind on this because they give a generic description, and the BMW's they do list they don't have a X5. Vehicle is 10 years old and lack of info. I can find the OBD connector, but not the factory connector. The VIN is 5UXFB33562LH35730. 4.4L
Re: 2002 BMW X5 Factory DLC Location
I have a picture that shows the round connector tucked in behind the OBD connector.
- nickscarcare
Identifix says underhood, LF strut tower, not there. It is not located by the OBD2 connector. Someone told me they may have gone away with it? I was hoping to catch a BMW expert on here that could say, Yep its right there!
I'm no help; I turn away almost all BMWs cause I don't like them.
I also see the connector behind the obd2.
- nickscarcare
Well I even dropped the panel, and it is not there. Guess there are no BMW gurus out there to help. Unless this one don't have it. Guess I will have to just use the global port.
Identifix shows it under the hood, but its not there either.
Thats why i avoid these things. all that work for free sucks. and ususally they expect u to be less then the dealer lol
Most of the post 2000 model BMW's only have the DLC-16 OBDII diagnostic connector.
I use the OBD2 port with my auto enginuity scanner and acess all modules on the Beemers..... Do not remember seeing the older style connector on the one of these that I have had in here, but it was an 01 so not sure about the 02, but would think it would be the same....
- nickscarcare
Yes I am guessing no 20 pin connector. I got the obd2 port to work, but since I have the capability and the cables, I always try to use that port. Thanks for the replies.
