2004 Volvo V70 2.5t Cam Seals FIXED
erlesauto
Post by erlesauto »
Any tips on doing cam seals 2.5t with vvt.
Re: 2004 Volvo v70 2.5t cam seals
I would make sure the breather isn't plugged first. If this is the first time you've pulled a vvt pulley i would follow the timing belt guide. You need a tool to lock the cams. It may be the vvt pulley leaking as well.
erlesauto
Post by erlesauto »
Cam gears move back and forth approx 3/4- 1" suppose thats not good
1000 Club: Interstellar
Post by Pauls Automotive »
I believe that is normal. With no hydrolic pressure in them they can move free. We have done a few of these and they all ove free. Folloow the reassebly procedure very closely. Also as Steve mentioned maked sure they are not leaking as we have run into that as well.
Re: 2004 Volvo V70 2.5t Cam Seals
Again, you need to be extremely careful when doing this. You can get away changing a timing belt if you'r super careful without any special tools. HOWEVER if you take gears off they need to be set to factory specification. The outer gear is set up , locked to the hub, belt is installed and than gear bolts are loosened and hub set. If it's not done correctly you'll have a power issue.
erlesauto
Re: 2004 Volvo V70 2.5t Cam Seals FIXED
Post by erlesauto »
Replaced Leaking VVT units and cam seals. Bought tool off Ebay, works like a charm
Hooray! Thanks for posting the resolution.
My tool sits and collects dust but once or twice a year when i need it i have it. If you don't need to remove the gear and are real careful the belt can be replaced. I've had more than a few but less than a bunch come into my shop with power issues and a fuel mileage drop after another shop changed the belt.
Return to “Imports - Other”
