Ok, here is a question that will make you wonder what I smoked/drank for lunch.
I tend to make some serious notes at times (carry over from medical documentation) on RO's. I have to go through each line, one by one, to be sure it is marked to not print on the invoice. What I enter is nothing the customer really needs to see. Is there a way to mark a RO to default to not print notes?
I know..that makes no sense dude! And i may be the only one to ever use it. But I'd be bummed to find out it is possible and not have figured out how.
TIP: Handling Notes? Revisions
- notes.PNG (17.26 KiB) Viewed 16679 times
- nickscarcare
Re: Don't print Notes?
I use this also, it would be nice to also set it to default.
I really did read ALL of those notes!! LOL!!
I don't think there is a global option to turn off all notes on a specific order. Imagine the havoc when someone enables that by accident. Yikes.
Would it make sense to just do it all on one or two notes; have a line for each entry? That might make your job of making sure they're not set to print a little easier.
One or two notes would be an option...however, "gremlins" here tend to only read what can be seen on the monitor and not open to Labor/notes to read what can not be seen.
Point taken. I feel for ya.Rich wrote:One or two notes would be an option...however, "gremlins" here tend to only read what can be seen on the monitor and not open to Labor/notes to read what can not be seen.
Raising this from the dead, but I'll tell you a workaround I do. On the revision's tab, I label one of the sub's Notes and write them there, moving them back and forth from the Order tab as needed.
