2016 Suburban - No Diff Fluid Specs?
- nickscarcare
1GNSKJKC5GR132068 Not sure if this is the right spot or not, but have a 16 Suburban and go into fluids, and no spec for front or rear differential.
Re: 2016 Suburban - No Diff Fluid Specs?
This is the place; inquiring now.nickscarcare wrote:1GNSKJKC5GR132068 Not sure if this is the right spot or not, but have a 16 Suburban and go into fluids, and no spec for front or rear differential.
The actual specs listed:
FRONT FRONT REAR REAR Navigation from Product Content Support:
Is it shown from the management program ?
- Mitch.JPG (27.29 KiB) Viewed 10879 times
It is not included under the Fluids button.
- nickscarcare
Sorry yes I should have posted that it is listed under procedures, but not fluid tab, sorry, but you did see that.
