2018 CHARGER 3.6L OIL IN COOLANT
CAR WAS TOWED IN, FOUND OIL IN THE COOLANT AND NO OR LOW ENGINE OIL ON THE DIP STICK. LOOKING FOR THE BEST WAY TO CLEAN THE ENGINE OUT DUE TO ALL THE OIL IN COOLANT
Re: 2018 CHARGER 3.6L OIL IN COOLANT
We use liquid dishwashing detergent. Low suds and works well.
Wow, flashback to my auto recycling days:
Not uncommon to have oil & coolant mixed in 8-318, 8-360 and 8-400 Mopar engines; the aluminum timing cover typically eaten away allowing them to mix. Clean the engine then put a good cover on with new gasket and run it to get compression check to confirm it can be sold.
