2001 VW Jetta GTI - 1.8L Turbo Erratic Coolant Sensor
I am working on a 2001 VW Jetta GTI 1.8 turbo. At times the temp guage will drop to cold and then come back to normal temperature. The car runs fine. According to the wiring diagram it looks like a fairly simple circuit. Only the temp sender and the cluster. This is the second Jetta that I have seen do this. The first customer decided not to investigate. Anyone seen a common denominator on these cars? I checked and did not find any TSB's
Re: 2001 VW Jetta GTI - 1.8L Turbo Erratic Coolant Sensor
I've replaced plenty of senders on VW's. Seems to be very common in these parts.
- fortknoxx
ha, ha. I got the same prob here. When my temp gauge works in my car, my l/r door will not lock with the remote. When my l/r door locks, my temp gauge don't don't work. Finally threw a CEL, read it. it was po117 i think, something about temp sensor input low. fans kick on, a/c and heat work.
Three little birds.
Three little birds.
what temp is the scanner reading during this?
- fortknoxx
when the gauge works it reads normal. when it doesn't work the needle just stays in the park position.
