SE 6.4 WIP columns
slowtech
SE 6.4 WIP columns
Post by slowtech »
Can WIP columns be moved around so most-used appear to the left and not used to the far right?
rhillig
Re: SE 6.4 WIP columns
Post by rhillig »
You can click & hold the top column labels & move them around. So you have the most used items on the left hand side & do not have to scroll.
Be to set this up under your user name! if you do it in the "default" user it will go back to the way it was everytime you log out of the program.
Re: SE 6.4 WIP Columns
Because the steps to Add a User are different in SE, I added a clip to show how in Knowledgebase: https://kb.mitchell1.com/articles/id-182
slowtech
Post by slowtech »
Thanks! Worked just like you said. Tom.
MIDMOTRUCK
Post by MIDMOTRUCK »
Tim - I can't get the column titles to highlight. Is there a special way to get this done. My invoice number column has moved to the far right side of the page and I need it back to the far left side.
Thanks,
MID-MISSOURI TRUCK & TRAILER PARTS, LLC
2480 E LIBERTY ST
MEXICO, MO 65265
Ph: 573-581-6400 FAX: 573-581-3030
[email protected]
In SE the column doesn't actually highlight; the properties are set to sorting the column instead.
All you should need to do is single click on the column name and start dragging to the left. You will see a phantom box as you move indicating that a move is in progress. Depending on how many columns you have to skip over, it might take a couple times to get it where you want it.
