Manager SE 9.1 Job View release
Daniel Kreider
Re: Manager SE 9.1 Job View release
Post by Daniel Kreider »
Daniel - please check to see if this got toggled off:
[/quote]
Yes, that had been toggled off, so it was toggled on again and the program was restarted but the symptoms are still the same on an existing work order.
But I did discover that when changing job specific category on a newly added job, the system works as designed for only the first time the job category is changed but not again after that (ie if the category was improperly assigned in the first place) ... hopefully this makes sense.
Daniel Kreider wrote:
Fri Nov 22, 2024 7:59 am
[/quote]
Yes, I follow what you mean. This is as designed. The suggested workflow is to use the Job Category selection in the final phases of work - it's a quick way to set missing categories, but we even debated going this far (thus the option).
Nothing is set in stone, so we'll be evaluating feedback on it over the coming months and possibly tweaking the behavior.
SwiftTurtle
Post by SwiftTurtle »
Silky7 wrote:
Fri Nov 22, 2024 7:38 am
dtsservice wrote:
Fri Nov 22, 2024 5:47 am
I am missing VIN digits on our printed invoices. The last 8 are there, and the first 5. Missing the 4 digits in the middle. Any one else having this issue?
We're working to address this. Keep an eye on this thread next week - support will likely post when a fix is available.
We have a fix for the incomplete VIN on Job View Headers available now. We will be including this fix in the next update but in the meantime please follow the instructions from https://kb.mitchell1.com/articles/how-t ... ew-header/ so you can use the updated reports right away.
BenjaminPeterson
Post by BenjaminPeterson »
When adding a item from the quick menu canned job is there away to auto make a new job instead automatically just going into the existing job.
How it works now
Screenshot 2024-12-04 143339.png (18.17 KiB) Viewed 50392 times
Screenshot 2024-12-04 143425.png (25.19 KiB) Viewed 50392 times
How we would like it to work
JPReilly
Post by JPReilly »
I would also like that change! While were at it I have a couple other issues/bugs with the update.
1. When you add multiple revisions it puts them all under the same job.
2. I don't like how it auto fills the job title in on non canned jobs. Wouldn't be bad if it was just a couple words but it fills in the entire labor description
4. Would be nice fi it automatically put the labor at the top of each job. Just reads nicer on the finished invoice
3. Would be nice if you could select and unselect jobs from the total price (like you can in the revisions sell screen) That way if a customer doesn't want to do a particular job you can just remove that from the total price on the fly.
Thats all for now... Def have some additional things that take some time getting use to but those are the big ones!
JPReilly wrote:
Thu Dec 12, 2024 8:29 am
Thanks for your input.
#1 is definitely a bug we're working to address. The ability to select/unselect jobs for preview of adjusted total pricing was a feature I wanted to get in, but we didn't have enough time. I'm still keeping it on the list though!
BenjaminPeterson
On some RO's the three dots are not on the end and I cannot delete the extra blank job.
Screenshot 2024-12-13 112539.png (9.18 KiB) Viewed 50161 times
BenjaminPeterson wrote:
Fri Dec 13, 2024 8:29 am
That's odd. Perhaps try changing the font size/option or the column widths? See if it reappears?
If not, please do reach out to our support so they can record the issue.
JPReilly
Post by JPReilly »
I have found with #1 on my list that if I drag and drop the different jobs to a new order it does separate them. Not exactly a fix but better then retyping the jobs.
Dixon
Post by Dixon »
I also see "no updates available" even though I'm at 8.5.3.1226. Called support today for a different issue and he pretty much 'got onto me' for not updating. My dad isn't good with computers so I said I'd call back another time. HAHAHAHA
Dixon wrote:
Tue Jan 14, 2025 1:36 pm
Hello - Support agent looking into this; says "If their host OS is win 7 or server 2012 it won't prompt or allow them to update."
Do you know which version of Windows you're running?
EDIT: Support says the Check For Updates should be done on the Host computer and not one of the workstations. The agent misunderstanding is being addressed on our side.
Dixon
Post by Dixon »
Howdy! Yea, I understand now it's a server issue on our end. M1 files need to be ran manually. I may just have your team handle it so there's no issues caused by me. They call me Chaos Coordinator for a reason... it's a fun life.
Edit/Follow-up: SHOUT OUT to the helpful folks in support. They handheld with utter kindness and offered some work arounds, if needed, due to a delayed costly replacement of our server.
We appreciate you taking the time to provide feedback on your support experience. January is always a hectic time in support, and it's always great to share positive notes with them.
chris.corlee
Post by chris.corlee »
All I can say is- You guys hit a home run with this update!
chris.corlee wrote:
Thu Jan 23, 2025 12:29 pm
Much appreciated!
We're following it up with some more exciting features in April. :D
demartileauto
Post by demartileauto »
Is there a way to revert back to the old invoice layout? Everyone (except me) hates the new layout, and they want it changed back. If I go to presentation and unselect group by job view it still prints the invoices in this new way, just unorganized. They want the labor on one side and the parts on the other like it used to be.
demartileauto wrote:
Mon Jan 27, 2025 12:52 pm
Yes - this is quite simple. You can actually turn Job View on, and leave it on for the other benefits, but then go to File > Print Setup and select alternative EST and INV templates.
We are cleaning up spacing, ref/invoice and a number of other smalls items on those templates for 9.2 (the next major release) so you might want to take a look again in the future.
demartileauto
Thank you,
If I had it my way I'd keep the new layout. But it's not up to me, unfortunately.
blakevosburg
Post by blakevosburg »
** Job View Enhancement request ** - could we see an option to toggle the Shop Supplies Fee on/off per job container? Another option would be the ability to manually override the total shop supply dollar amount that is auto calculated for the entire invoice. Basically, we pick and choose which services get the fee.
Return to “SE News”
