2001 Ford F150 - 4.2L VIN 2 Lean
Re: 2001 Ford F150 - 4.2L VIN 2 Lean
Great fix. I learned a long time ago when working on a Ford and there are issues with no defined codes such as rough idle, no power during acceleration, lean readings from the 02's, etc i replace the MAF. The readings are close enough where you think it's fine and no code it's still junk.
woo hoojbadenoch wrote:freeze frame info can sure help. I've had quite a few fords with 174 and171 where the maf tested good but was not. Intermittent issues i guess. Just 3 cents worth. Let us know what ya find. Good luck and stay cool, 105 deg in sc
What is really awesome is that the Ford dealer has been fighting this code for 2 years, and it took less than a month with your help for me to fix it. Now the customer says he will be bringing all of his vehicles here instead of the dealer!
20 Years with General Motors
L1 Recertified
L1 Recertified
