Remove Shading?
stkauto
Remove Shading?
Post by stkauto »
How do I remove the shading of lines for example on posted orders report, every other line is shaded. This uses lots of toner. im cheap!
also on the invoice the shaded line across the parts description/ number qty sale... line
I'm sure there is a setting in set up im not finding.
Re: Remove Shading?
There is no setting to turn off the shading, it is part of formatting applied to the templates that generate the reports. You might be able to set your printer to 'draft mode' that will use less toner.
stkauto
Re: Remove Shading?
Post by stkauto »
So there is not any place in Mitchell 1 program to eliminate the
gray shading in the posted order report? Every other line is shaded
and I am use to highlighting any charged sales. Not its hard to high light
when every other is already done and does not need to be.
Thanks :D
Re: Remove Shading?
Welcome to the forum and thanks for your question.
The point of shading on reports is to make it easier for users to read across rows without losing their place. We cannot always anticipate what else someone does with them.
