More LOF packages & Categories
Eaglesoar1
Post by Eaglesoar1 »
I looked at http://managerforum.net/viewtopic.php?f=21&t=1876 and didn't see this on the list.
Under the current architecture, there are 5 oil changes listed for 4 different categories of LOF packages.
In my case, I want to be lazy & have 8 packages under one category for my synthetic oil changes. (5qt, 6qt, 7qt, 7.5qt, 8qt and then all the different weights - 0w20, 5w20, 5w30, 15w40, etc.)
To my way of thinking - if we can have 5 why not 8 or 10 or 20?? :)
I think we as shop managers should be able to add LOF category buttons ( for the weights) AND the # of packages we want under each category - IMHO>
I hope I described this to where everyone understands. (Probably not)
Eagle Automotive
http://WWW.EAGLE-AUTOMOTIVE.COM
People say I suffer from OCD - I do not.
I suffer from CDO which is like OCD just in alphabetical order - LIKE IT SHOULD BE!
Re: More LOF packages & Categories
I think we get it. You mean something like this? (Ignoring the actual values)
Eaglesoar1
Yes! THAT'S IT!!!
On the one category you screenshot here - I see you have 7 packages listed AND even added enough jobs to have a scroll bar for even more!!!
How'd you do it???? :shock:
I called product support and they said to post it out here under enhancements because they didn't have a ready solution.
I WANT, I WANT, I WANT!!!!
Eagle Automotive
Sorry, just a mockup designed to show a rough outline of what you described. :oops:
The real thing would take some code changes in the manager application to allow you to add/remove more packages. I just wanted to make sure it was clear for Product Management.
Eaglesoar1
DARN!
I thought you had it nailed!
Well, that is what we were wanting - hope this is an "Easy" fix so it moves towards the upper part of our wish list.
Thanks for the "hopeful" preview!
Eagle Automotive
alloutrepair
Post by alloutrepair »
Just an idea, but using canned jobs is a very good option for oil changes. It took me a bit to set them up, but I love them, and it's just as easy to add them to the job. Now I know which oil filter I used, and what type of oil I used, because I selected them when I added the oil change to the order.
I setup 3 canned jobs: 1- std oil change; 2- blend oil change; 3- syn oil change
I setup 4 parts kits: 1- std oil change; 2- blend oil change; 3- syn oil change; 4- oil filters
(When setting up the kits, you choose the amount to retail these items for and ask it to prompt for each item.)
I added the appropriate oil kit and the filter kit to each of the canned jobs.
I selected the option to add the canned jobs to my quick list.
Now when a customer comes in for an oil change:
-I find out what oil and what filter is needed
-I right click on the first line of my order and select the oil change that they are looking for (let's say syn)
-A window pops up to as what filter I am using and after selecting it I click 'okay'
-Another window pops up to ask what oil I am using (and it only shows the synthetic oils I have available) after selecting the one I want I click okay, and all 3 lines are added to my order with the correct part/inventory I am using.
As an added bonus, the tech doesn't need to look it up anymore, because it is on my Tech Worksheet! :lol:
THANKS!
~Jennifer~
AngelsAutoCare
Post by AngelsAutoCare »
We use canned jobs as well for oil changes.
A regular oil change is a set price for up to 6 quarts of oil. I still inspect how much oil every vehicle takes unless I know off the top of my head and write it on the tech worksheet or add price as necessary to the customer.Synthetic and diesel oil changes I charge by the quart for each particular application, but each type of oil has its own job already setup and I just have to change the quantity... It is very simple and easy to use!
We also use a canned job for lof's. We also set up the whole job filter and oil and leave it in a revision for easy transfer for every service. If it takes a special filter or oil not stocked I make notes to try to remind us to order it before the appointment.
ARS
Post by ARS »
Are the LOF Packages that we are seeing in MItchell working... last time i have seen it is a mock up design... Just wondering.. because it seems like it would be something we can use.
Thanks, ARS
LOF/Brake/Tire packages are all under consideration; but we feel the Schedule is probably the next major component we want to address.
ARS
Post by ARS »
OK, bummer... We saw it there hoping it was good to go... WE will try it a different way... Thanks
Just for clarity's sake, were you wanting the same thing as Eaglesoar1? Or something different done with LOF?
ARS
Post by ARS »
We are trying to make our oil changes more uniform...
ie. Reg. LOF with 5 qts - 34.95,
Full Synthetic 5 qt LOF with Proselect filter $45.95 &
full synthetic 5 qts LOF with gold filter $59.95. or something like that ..
we are struggling on how to build a package like that. Right now if you called our shop & asked how much is an oil change, we honestly could not tell you with out looking up what your vehicle needs. WE can guesstimate it ( reg. oil - around $33 & synthetic $45) We do not currently carry gold filters yet. We have about 10 filters that are sell at 2.99. but other than that each filter is based off of cost (cost x 50%) & the oil is (cost X 35%). So every oil change price is different. We are trying to make it so when you call & ask, we can tell you & then make it so the ticket actually says what we tell them. We were hoping that the LOF package button would work..but...
How does MItchell or other shops handle this? We could really use the help...
Thanks, ARS
ARS wrote:We are trying to make our oil changes more uniform...
Thanks, ARS
I do them all vehicle specific. Since most take different engine oil and filter I charge vehicle specific. I also charge more labor time for newer Mercedes etc that require special tools to reset maint reminders. I try to sell them as a service instead of an oil change since more then changing the oil is happening. Since some of the vehicle get 5,000 mile intervals or 7,500 it may need a tire rotation every or every other time also. Once I know what is needed on one vehicle I save in on the last revision for easy copy and pasting to an invoice.
Thanks, ARS
We no longer offer menu pricing. Each oil change is an entity unto itself, and priced according to costs. That changes a lot, and so does the price. If a 'consumer' called here and asked for a price on an oil change, they would be asked YYM and an estimate would be created. We would then attempt to make them a 'customer' by education.
Menu pricing worked well 30 years ago because the differences between cars were small. Today is a different story.
rhillig
Post by rhillig »
ricmorin wrote: We no longer offer menu pricing. Each oil change is an entity unto itself, and priced according to costs. That changes a lot, and so does the price. If a 'consumer' called here and asked for a price on an oil change, they would be asked YYM and an estimate would be created. We would then attempt to make them a 'customer' by education.
I think this a good idea as well! I want to switch to this as well - too many variables.
That's what I was trying to say only he said it in a MUCH better way..... :!:
Return to “Tips + Ideas”
