After the latest update, part numbers have disappeared from invoices. Print setting is "INV with hours / no rev data". The only settings that would yield part numbers also put in revision data, which we don't want. The setting "INV with hours / no PN / no rev data" prints the same as the above setting.
Suggestions on how to get part #'s back on the invoices without adding revision data?
Thanks.
Part # disappeared from invoices
Re: Part # disappeared from invoices
I just printed an Invoice from History using the Inv with hours/no rev data selection and parts are there but part numbers are not. I don't see a selection with your specific requirements listed. Are you saying that part numbers were included with this selection previously? If so, someone could provide you with the older version of that report. What version are you on now and what version did you upgrade from?
Re: Part # disappeared from invoices?
This template has already been corrected for the next update.
Thanks, Tim... Any idea when that will be released so I can let the boss know?
I don't have a precise date for the update. I've been provided with the updated template that may be copied into a system now. I can email this with basic instructions in the morning.
EDIT: Check your email
