Double Tray Printer
john giles
Double Tray Printer
Post by john giles »
John we met in Nashville and you told me that you have a 2 tray printer I have tried a couple that tech line could not get to work. What printer did you get to work with SE?
John Giles
murraymotive
Re: Double Tray Printer
Post by murraymotive »
I am not John who you met in Nashville, but we use two of these at our shop.
Amazon Link
You have to configure the two trays during printer installation and then you will have choices to use within Manager.
john giles
Thanks
We're currently working on multi-tray support. A wider variety of printers should be useable with the next update release (Q1 2015).
john giles
Sorry I didn't say the John I am talking about John Dwulet with Mitchell
Hi John, John from Mitchell. I did get you message and tried to call you back a couple of time, even this morning, but you must be as busy as I. There is a defect in the way the software handle a printer with trays, it is now being fixed and an update for that will be forthcoming in a few week.
In the meantime, I simply print to screen. Then click print. Once there, I have the ability to choose the tray manually by clicking on the Properties button. A few more clicks, granted, but it gets you there now.
john giles
Thanks for the reply how will I know when the update is out, will it be posted here?
You will see a popup window in Manager SE to accept or postpone the available update.
john giles
Tim John I have the up date "6.5.54" will this do a 2 tray printer if so what printer do you recommend?
Yes, multi-tray printers are recognized as part of the SE 6.5.54 update.
We do not have specific model recommendations; most any name brand unit should suffice in regards to this parameter.
