American Tire Restock From Inventory
- cardoc
I love the American tire intergration. I now was going to set up all my parts to restock like all the other vendors I have. So I called my ATD office and they had no clue. Talked to the website people. No Clue. So I figure you guys would know best. Is there an intergration for tools and parts for inventory restocking or just tire ordering. If so where can I get the line codes needed. Alan
Quality is not expensive, It is Priceless!
ASE L1 Master Certified Automotive Technician,
Service Advisor, & AMI Graduate
ASA Member
ASA Member
Re: American Tire Restock From Inventory
Are you saying that you already have inventory records for ATD items? If so, you would manually enter stock levels and re-order points. If you need to add these records to your system for the first time, just open an order and select the items you want to create records for, transfer them to the order and then mark the Inventory checkbox for each. Then set the order points as mentioned above.
- cardoc
You only have tires and wheels listed that I can find. So is there a way to do wheel weights and valve stems and so fourth??
ASA Member
ASA Member
There will be a phase 2 implementation (likely next year) but I've not heard anything about ancillary items just whole goods (tires & wheels).
