Editing Customer Phone Numbers
edthewrench
Post by edthewrench »
Under the phone list, is there a way you can change the "phone location" heading to say something like "phone name" or "customer name", and then be able to add/edit who's number is associated with that number? Some customers have numerous contact numbers! Right now we're typing a customer's name in the extension# box....trouble is, there's limited characters available to do that.
Re: Editing Customer Phone Numbers
Unfortunately there is no way to do that now. Our only option is to use the extension field. Tim might elaborate on anything that might be 'in the works' in this regard.
If you change a label, which you can, you change it for every record. NOT DESIRABLE!!
edthewrench
ricmorin wrote:Unfortunately there is no way to do that now. Our only option is to use the extension field. Tim might elaborate on anything that might be 'in the works' in this regard.
Exactly......hopefully it's in the works.
It may very well be. It's been a lament on this forum for a while now. And it IS on the Enhancement Request List....
You an view all the Enhancement Request here.....
http://www.managerforum.net/viewtopic.php?f=21&t=1876
ARS
Post by ARS »
+1 on a needed fix... we use the extensions too.. but when they have a long name-- it looks weird on the invoice.
Rob@SD-AR
Post by Rob@SD-AR »
Can't you just make the extension field allow more than 5 characters, seems like this would be a quick fix/work around.
Return to “Tips + Ideas”
