Unusual Maintenance
Unusual Maintenance
Subject vehicle is a 2013 Honda Pilot Touring 3.5. Under Service B it states Inspect T-case fluid, but the description after shows replacing the fluid. Maintenance 3 indicates replace. This should be corrected.
Re: Unusual Maintenance
Agreed, did you run that through the FEEDBACK button?
I believe my SA did, but I will check for sure.
Return to “Using ProDemand”
