I added a couple Resources to test things, and now that i want to use them for something, i can't delete the one that i don't want to use.
Any way to do this?
I've setup the resources to use as Waiting and Drop Offs since adding a dropped off vehicle makes the schedule hard to read/use.
So now i have one set of appointments that are waiting, and another that are dropped off, and they are in their own columns.
However there is a 3rd that i created that i don't want to use, but i can't delete it, and it's a pain to uncheck it every time.
Delete Resource? 7.0.11
Re: Delete Resource? 7.0.11
Looks like there is no delete, but there is a check box to make inactive. Try selecting that, shutting down all instances of Manager and restarting. That should remove it from view on the Scheduler.
that will work, thank you.
Did not work for me. All instances shut down except host. Unchecked "unassigned". Closed SE on host and restarted. "Unassigned" still automatically checked.
Frank Panipinto
Frank's Tire & Service Center
Don't make me ...hungry, you won't like me when I'm ...hungry
Frank,
The inactivity check will remove any user-created resource or technician. However, Unassigned is a built-in item that cannot be set as Inactive at this time.
Gotcha... thanks.
Frank Panipinto
So there's no way to delete a User-Created resource? I see that in can be set "inactive", but not an option to delete it. Am I missing something?
That is correct at this time.integrity1 wrote:So there's no way to delete a User-Created resource? I see that in can be set "inactive", but not an option to delete it. Am I missing something?
