Hello,
We are trying to apply 2 different discounts to an invoice. The first discount would be if a customer brings in a coupon and the second discount would be if a customer is using their loyalty dollars from our loyalty program. It is important that they are tracked separately. Does anyone have a solution they have successfully implemented?
Thanks!
Applying More Than 1 Discount / Loyalty Dollars?
- gordiesgarage
Re: Applying More Than 1 Discount / Loyalty Dollars?
I would use the coupon as a discount. I would set up a GL code for loyalty dollars and use it as a pmt source. both could be tracked that way.
- gordiesgarage
Thanks Jeff. I appreciate the input.
Joe Hanson
My pleasure!
