I have noticed something strange in the last few weeks. No one else will be working on the Mitchell program & I will have the WIP screen up on my computer. I will notice that the screen "refreshes" as if someone as finished a work order or started a work order.
No one else is in the building at the time & none of the other computers have the Mitchell software open.
Do I have a gremlin or is this normal?
WIP screen refresh?
- rhillig
WIP screen refresh?
Re: WIP screen refresh?
That could be from the SE 7.x Schedule; typically just a few columns to the RH side, depends on screen size and column widths you have set up.
- rhillig
We don't use the scheduler, but do have full screen showing all the time. So that could be it.
We had a hacking experience a year ago & I'm trying to make sure it doesn't happen again....
The WIP grid has a normal 30 second refresh, at which time you may see items (newer ones in particular) shift location. If you want to stare intently at the WIP for a minute or so, you should be able to tell when it's a normal refresh.
I tried this. Couldn't catch it. Maybe I blinked. But I have seen it also and wondered what was going on.Silky7 wrote:The WIP grid has a normal 30 second refresh, at which time you may see items (newer ones in particular) shift location. If you want to stare intently at the WIP for a minute or so, you should be able to tell when it's a normal refresh.
- rhillig
After our whole hacking experience, I might be a little more sensitive to it. But thanks for confirming that I'm not seeing things!Silky7 wrote:The WIP grid has a normal 30 second refresh, at which time you may see items (newer ones in particular) shift location. If you want to stare intently at the WIP for a minute or so, you should be able to tell when it's a normal refresh.
Darn Russians
