POLL: Estimated Parts?
Registered Forum Members Can Vote! Forum members respond to business & software questions
Do you ever use Estimated Parts?
1) Yes
4
17%
2) No
10
42%
3) Used To
0
No votes
4) Don't know what that is
10
42%
Total votes: 24
Estimated parts has been in the system since the beginning; checking to see how much usage there is. Thanks
Re: POLL: Estimated Parts?
Yes. We use it on bigger jobs where the exact cost of parts is still unknown.
What is estimated parts?
I did at one time but since I have access to most of the OEM parts through the MORE website I pretty much do not use the MOD parts estimator. Through the MORE site, I can also order parts from the dealers.
Tim Martin wrote:I did at one time but since I have access to most of the OEM parts through the MORE website I pretty much do not use the MOD parts estimator. Through the MORE site, I can also order parts from the dealers.
Estimated parts has nothing to do with MOD Estimator. It is a field within a labor to add some unknown parts cost to the order without creating a parts line.
nickscarcare
Post by nickscarcare »
I agree, what is estimated parts?
Estimated Parts
Estimated Parts
ricmorin wrote:
I guess I have never used that. How do you all use it?
1000 Club: Interstellar
Post by Pauls Automotive »
You know I have seen that for years and never even dawned on me to question what it was for. LOL :roll:
[email protected]
My bad, but the way the initial question was worded I didn't pick up on the usage.
brianp87 wrote:
On larger jobs where there may be a lot of little parts that may add up to a significant amount, I add a dollar figure in that window. For example, an engine job may have 50 dollars of little parts which can be accounted for here.
I have tried this but don't see any change in the invoice dollar amount beyond the labor dollars I charged.
[email protected]
Pauls Automotive wrote:I have tried this but don't see any change in the invoice dollar amount beyond the labor dollars I charged.
It's for use at the Estimate stage or Revision. That's when the amount placed there is figured into the calculation. Once at the RO stage, the field is ignored. Ideally you'd assign a value there before customer approval. Then when approved, either by converting the Estimate into an RO, or by transferring a Revision the value is added to the total approved amount. It's ignored after that because you'd be replacing it with your itemized parts.
In short, it bumps up your estimate a little to account for the unforeseen.
Thanks Ric. That makes sense. I was trying at the RO level. I will retry with an estimate.
[email protected]
I go to the parts entry and type M10, M20, M50 or M100.
nickscarcare
Always saw it, but never used it. I just add a parts line and put misc, that way the tax shows up also.
sbcauto
Post by sbcauto »
I Do Use It Often. More To Get Oem Part Number To Use Interchange.
sbcauto wrote:I Do Use It Often. More To Get Oem Part Number To Use Interchange.
Not Estimator or Estimate Guide parts, we're talking about this field in the Labor item entry window:
fortknoxx
Post by fortknoxx »
I never noticed it, all of the years I used the software. I knew Ric would be using it.
Return to “Polls”
