Mobile Manager VIN Decode Error
Mobile Manager Pro (tablets)
I've noticed about a half dozen times now that Mobile Manager has difficulty decoding VIN's from Hyundai. What occurs is a digit is dropped from the beginning and another digit is added to the end. The net result is the inability to decode and I'm relegated to go to the laptop and correct it.
Here is a screenshot of how the vin was decoded by Mobile Manager....
error decoding vin by Mobile Manager
This has happened enough times that it's more than just random.
1000 Club: Interstellar
Re: Mobile Manager VIN Decode Error
Post by Pauls Automotive »
I noticed you have a unit # in where the tag number should be. Why not use the tag to decode? As a work around.
These vehicles don't have tags yet. :roll:
Auto Repair Coach
Post by Auto Repair Coach »
I'll get this in front of the programmers to check out.
Just the same, do you enter the unit number before or after you decode?
I am assuming that you are using the VIN to decode since there is no tag.
Are these 2018 models?
John Burkhauser
BOLT ON TECHNOLOGY
Before. The unit numbers are provided to us by our customer in advance.
Yes, that is correct.
No. Most are between 2003 and 2012. I believe the example is a 2010.
Just to be clear, I've only experienced this with Hyundai. No other manufacturer has exhibited this behavior yet,
Auto Repair Coach
OK Ric,
Thanks. Just trying to ask questions prior to submitting the issue. As usual, you are on the ball. Thanks.
John Burkhauser
BOLT ON TECHNOLOGY
Any fix to this yet? I got another Hyundai that decoded incorrectly in the exact same manner as described in my original post.
Auto Repair Coach
Nothing noted from original request. Rechecking today.
John Burkhauser
BOLT ON TECHNOLOGY
Return to “Mobile Manager”
