Update
- nickscarcare
Update
Trying to download to the 7.3 update, keeps telling me it can not download, check internet connection. Well obviously I have connection. I suppose this is a techline call.
Re: Update
Yes.
- Gary R
Re: Update
Does this update effect users running Windows 7?
Re: Update
All,
The problem is with Microsoft's new .NET framework update. While it included in the Windows 10 April 2018, it is unknown when they will begin release to Windows 7 and 8 users. However it is quite likely they will in May.
Due to the unknown factors in this equation, the simple answer is everyone needs to update if you want insurance against being completely locked out of Manager.
Re: Update
Side note: it took our Host 50 minutes to run update.
Re: Update
Yes, apologies Rich. We have taxed every bit our resources to try to get the update out to as many people in possible in a very short time frame. Downloads are going slower than we'd like.
As many of you long-term users know, we usually send updates out at a metered rate over several weeks. This time we're trying to update everyone in 6 days.
Thank you all for your patience and understanding during this event. Believe me when I say that we too wish we were never forced into this kind of rushed pace for updates.
Re: Update
15 minutes to download and 5 minutes to update host. Not bad.
Re: Update
I'm not complaining!! Just wanted folks to know. I was going to do it "quick" between phone calls. Just didn't want any one else to try my bone head ideas!Silky7 wrote:Yes, apologies Rich. We have taxed every bit our resources to try to get the update out to as many people in possible in a very short time frame. Downloads are going slower than we'd like.
- nickscarcare
Re: Update
I tried again this morning before I called tech, and it worked, took about 30 to 45 minutes each on both machines.
Re: Update
Struggled a bit with this update time-wise. One of the client PC's even timed out at about 3/4 of the way thru the download...luckily it restarted where it left off.
Is there a technical reason why when you update the Host that the update is not saved for the clients to update from it thereby allowing the client PC's to update over the LAN without going over the Internet?
Re: Update
Yes, there is actually. Our Updater software is designed to distribute from your host to your workstations using WCF calls in your LAN. Unfortunately as we've discovered over the years, this distribution method doesn't always work. Additionally, to use the Updater mechanism, we have to specify your account is eligible. This direct update mechanism was put in place for those of you that would like to get the updates yourself, and to allow you to update a workstation that couldn't get it in the LAN due to the WCF failing. It was never intended as the primary mechanism, but it can serve out more updates in a short period of time than our normal Updater. Due to the very short notice on the Windows update, we wanted to go as fast as we could to everyone, and used this "secondary" update process as the primary method.GUTHTIRE wrote:Struggled a bit with this update time-wise. One of the client PC's even timed out at about 3/4 of the way thru the download...luckily it restarted where it left off.
Hope that helps.
