How To Start MessageCenter / Lube Sticker Printing
rp2756
Post by rp2756 »
OK, couple questions, the option to print LOF stickers is on the new update, what printer should we be using or doesn't it matter? Next, how does the text option work? Do we have to use one of our cell phone numbers? Im really interested in starting to use both options.
Re: How To Start MessageCenter / Lube Sticker Printing
Manager SE Splash screen button changed to include:
sticker button.png (9.17 KiB) Viewed 17462 times
It takes you here for printers and supplies: https://mitchell1supplies.com/store/store/landing.asp
MessageCenter added + Lube Sticker setup has been added to Configurations - Reports/Printers menu:
To start with MessageCenter ($29 per month), please contact your local Mitchell 1 representative or call us @ 888-724-6742 and follow prompts. Configuration is fairly simple after the order is processed, you will receive a Welcome email with login details for your dedicated texting # we provide in your area code*. (*subject to availability; mostly an issue for states with a single area code for entire state)
F1 Help for MessageCenter (working on expanding its content now) is here: https://www.buymitchell1.net/managerhelp/TextSetup.htm
rp2756
Post by rp2756 »
Thanks for the help
rp2756
Post by rp2756 »
Are there any Promo codes for the store when ordering a label printer? That would be very nice. LOL
Sauvageaus
Post by Sauvageaus »
How long until they get the texting set up, I sent in the information last Thursday but still waiting to get it set up?
Sauvageaus wrote:How long until they get the texting set up, I sent in the information last Thursday but still waiting to get it set up?
Typically it's within 24 hours of the order being processed. How did you order it, by local rep, phone or ?
Sauvageaus
Phone and then he emailed me what to fill out and I faxed it, he emailed me back saying he got the fax
Okay, checking with Order Processing now.
Okay, Order was processed on 10/12 so I'd think the Welcome email (with credentials) was sent by now. Please check spam folders as the 'sender' might be unfamiliar.
rp2756
Post by rp2756 »
Is there a 30 day trial on texting?
rp2756 wrote:Is there a 30 day trial on texting?
Yes there is.
rp2756
Post by rp2756 »
When I called in they told me there wasn't.
rp2756 wrote:When I called in they told me there wasn't.
As the product manager I can confirm there is. When you "called in", was that technical support, customer service or something else?
Yes there is.
This can be confusing in the communication between customers and our support personnel. We generally refer to new product additions as subscription with a 30-day opt out period.
The word "trial" tends to have the connotation that it will simply end if you were to take no action. That is not correct, and why you might be told there is no trial.
You would need to request cancellation explicitly during those first 30 days. If not, you would be continue into the contract period.
Hope this helps.
rp2756
Post by rp2756 »
Customer service I believe. He emailed me the paper work to get signed up. I have his name if you want it.
rp2756 wrote:Customer service I believe. He emailed me the paper work to get signed up. I have his name if you want it.
I believe Silky7 explained the disconnect above quite well.
rp2756
Post by rp2756 »
Well, he should have been able to explain that when I called, he just said NO. I assume he knew what I was asking. But now a days I guess you cant assume anymore. Im going to sign up and give it a try. Thanks guys.
Apologies for any confusion from our service personnel. Hope you like the feature!
Sauvageaus
This texting is awesome!
Sauvageaus
Sauvageaus wrote:This texting is awesome!
Is there way to send pictures of their vehicle or attachments?
Return to “MessageCenter”
