Using Quick Menu Wipes Clipboard?
RIORYAN
Post by RIORYAN »
I frequently do the following -- view history to see last oil change package, copy (ctrl+C) the oil change parts, go to a new work order, use the quick menu (right-click) to add the labor, and then paste (ctrl+V) the parts.
The problem is, as soon as I use the quick menu (right click) to add the labor line, it clears the clipboard and I can no longer paste anything. I need to go back into the history and copy the parts again. This is a repeatable issue for me. I can copy & paste parts but once I add an item using the quick menu it will lose my copied parts.
Re: Using Quick Menu Wipes Clipboard?
I've found over the years there are several parts of the program that does this. Now that you know, bring your labor line over first -or- why bother doing this every time? Simply create and store the entire oil change job in Revision 9 for all vehicles. It's always ready for a copy/paste and is much more efficient.
rhillig
Post by rhillig »
RIORYAN wrote:I frequently do the following -- view history to see last oil change package, copy (ctrl+C) the oil change parts, go to a new work order, use the quick menu (right-click) to add the labor, and then paste (ctrl+V) the parts.
One thought - paste the parts before you quick menu the labor. You can drag the labor line to below the parts if you want. (Unless I am misunderstanding your process)
Also - we use the memo field and put the oil, quantity & filter. You can check it so it doesn't print on the invoice, but it is handy as the memo gets transferred over as soon as you put a labor item on there. So you quick menu the labor & the parts listing shows right up there for you to manually add.
Not ideal - but things to try.
