purge estimates not working
Good afternoon. I searched before adding this thread., but it was locked. I cannot purge estimates and haven't been able to in some time. I write a good number of estimates daily, currently need to delete 100+. Version 8.0.3 Error screenshot attached.
Re: purge estimates not working
sorry, screenshot didn't post earlier.
- purge error.png (54.91 KiB) Viewed 3953 times
Thank you for posting on the forum; this type of issue is beyond the scope here and it needs to be addressed by tech support directly.
Please contact them ASAP. 888-724-6742 and follow prompts
You can also try to address this yourself if so inclined. The error is saying you used ProSpect to transfer a canned job to an estimate, but never opened the estimate to process it. Given they time frame, I'd say you're looking for an estimate in late March with a DVI. Just open that one, process the pending CJ, remove the MPI and then you should be able to purge.
Silky7 wrote:You can also try to address this yourself if so inclined. The error is saying you used ProSpect to transfer a canned job to an estimate, but never opened the estimate to process it. Given they time frame, I'd say you're looking for an estimate in late March with a DVI. Just open that one, process the pending CJ, remove the MPI and then you should be able to purge.
Cleared it right up. Thanks!
