Apply tax to, labor
nickscarcare
Apply tax to, labor
Post by nickscarcare »
8.5..2.670 So I set up a canned job for undercoating, here in MN tax has to be applied to labor for undercoating, I go to tax in the canned job when set up and it says applied, but says that for all canned job labors I see, but when it is transfered to a repair order it does not tax automatically, only if I go tom that labor line and click tax, then hit apply tax to labor? What am I doing wrong?
Re: Apply tax to, labor
A control was added to make departures from default labor tax settings.
When you open the tax table for that labor item in the Canned Job you gain access to this:
Tax option labor.png (32.9 KiB) Viewed 22732 times
nickscarcare
Yes that is all clicked, and still does not apply tax to labor when put in repair order
nickscarcare wrote:
Mon Dec 11, 2023 1:35 pm
My thought was that the checkbox to be UN-Checked.
If your labor is set to non-taxable labor, with the box checked (default), it's just going to follow that system setting.
Unchecking the box exposes the tax table where you can specify tax #2 as needed for the Canned Job.
nickscarcare
Unchecked, checked all stays the same, even have the account class set to labor taxable, still no avail. I am guessing there is not a fix to this problem. We cant be the only ones who have to put tax on some labor items.
nickscarcare wrote:
Wed Dec 13, 2023 10:26 am
I think you missed a step where you needed to check the box in the canned job; it does work as follows:
1. The labor tax needed exists in your tax table (line #2 or similar)
2. The labor line in the canned job has the checkbox unchecked (exposing the tax table)
3. Check the box for the labor tax on line #2 (or similar) and click OK to save it.
4. Sell the canned job and observe the tax on the order has changed accordingly.
CJ labor tax.png (77.61 KiB) Viewed 22641 times
nickscarcare
Screenshot 2023-12-14 162217.png (186.14 KiB) Viewed 22563 times
nickscarcare
That is what I have
nickscarcare wrote:
Thu Dec 14, 2023 2:23 pm
That is what I have
Okay.
1. UNCHECK the box for default tax rate.
2. Then select the tax on line #2. (we believe you have this in your database already)
3. Click OK to save this detail of your canned job.
nickscarcare
Well I believe that worked, I thought that box would have had to be checked to have the tax applied. Hmm seems to work now thanks!!!!
nickscarcare wrote:
Fri Dec 15, 2023 11:46 am
Great. That box is checked by default so it was just gonna follow how it normally works. By unchecking the box - that's what frees you to make that ALTERNATE tax behavior. :wink:
nickscarcare
I was thinking if it was checked it should apply, thats the way it reads since the heading at the top says labor is taxable
nickscarcare wrote:
Mon Dec 18, 2023 10:35 am
Right; I think the initial setting displayed at the top is incorrect on a system where the labor is defaulted to non-taxable.
That reminds me; the account class (revenue bucket) for THIS item should be set to Labor (Taxable) as all your labor normally gets recorded under Labor Non-Taxable. The invoice was going to be correct, but certain reports might be off a bit.
Labor taxable.png (27.61 KiB) Viewed 22127 times
nickscarcare
Yes I already had labor class taxable there. Thanks again for the help!
