1990 Ford Econoline E150 - Fuel Guage
the fuel guage will only go up to 3/4 of a tank.I installed two new sending units,also when i ground the wire to the guage it goes up to full.
Re: 1990 ford econoline 150
Did u look inside tank? maybe a baffle came loose and is holding the sending unit float down so it cant go any higher than 3/4?
Did u order the sending unit for the right size tank? If you order a 40 gal sender for a 30 gal tank it may only show 3/4 tank.
- wbuxton
Going out on a limb here. Check to see if it has a "slosh module" it replaced the IVR on the back of the Instrument Panel. IVR looked like a 9 volt battery plug in. Slosh Module is an electronic shock absorber.
William
Weatherford, TX
817-599-7680
866-744-3887
http://www.phoenixtrans.com
William
Weatherford, TX
817-599-7680
866-744-3887
Re: 1990 Ford Econoline E150 - Fuel Guage
resistor in the back of the cluster. i believe it just pops on with connectors like a 9v battery has.
Does it have single or dual tanks? I'm assuming single, but I got to ask first.
Replacing the guage repaired the problem.Thank you for all your help.God bless
