2002 Subaru WRX - Sub-Frame Labor?
Mark F
Post by Mark F »
Hello,
Would anyone have the labor time to replace sub frame on this fine auto.
Thanks ...Mark
wbuxton
1000 Club: Interstellar
Re: 2002 Subaru WRX - Sub-Frame Labor?
Post by wbuxton »
Transmission R&R is around 4.5 depending on manual or automatic and/or normally aspirated or turbo. So, I would say 2.0 would be more then fair for you.
William
Weatherford, TX
817-599-7680
866-744-3887
http://www.phoenixtrans.com
Mark F
Post by Mark F »
Thanks.That sounds fair.. Mark
liljoe
Post by liljoe »
When I looked in MOD5.com it showed 5.8 for crossmember replacement. Don't know if this is correct or not.
WRX SUBFRAME LABOR.jpg (140.33 KiB) Viewed 3998 times
sub frame = crossmember, correct? i looked under suspension and saw cross member as 5.8 without alignment. the year of the car is border line where i raise my labor rate depending on rust, wear and tear.
Mark F
Post by Mark F »
Sub frame not connected to cross member. Looks straight forward. The only thing connected to sub frame is radiator mounts. Will account time for rust on labor time. Thanks for the help...Mark
Return to “Imports - Other”
