Toyota - Pesky PO420 DTC
Does anybody out there have a good way of diagnosing this trouble code? Is there a good way of determining whether the problem is the downstream O2 Sensor or the cat? I have so often followed the diagnostics given in a troubleshooting flow chart only to wind up replacing both the sensor and the cat. I got a 01 Toyota Sienna in here right now with the same issue. These cats are costly on this one.
Re: 2001 Toyota Sienna - Pesky PO420 DTC
Monitor the upstream and downstream O2's on a scope. See if the post O2 is following the pre. If it is, the cat is probably bad. As you know, that post sensor should be steady after the cat lights off. Toyota is usually good about identify slow O2's and bad heaters. I use a generic laptop scanner for this so all I have to do is plug into the OBD port.
I also see how they are switching. I do find alot of bad aftermarket cats.
- Pauls Automotive
I do the same. I always to to go OEM when replacing cats. Too many problems otherwise
[email protected]
[email protected]
- crmeyers
Like Ric stated in the above post, if the downstream O2 readings mirror the upstream, you've probably got a bad cat. I attached an example of a normal reading and an abnormal reading. And yes, stay away from aftermarket converters on these. They will bite you in the a@&!
- normal O2.gif (3.67 KiB) Viewed 13370 times
- faulty cat.jpeg (9.69 KiB) Viewed 13374 times
Understand the lab scope readings. So what is being said is that if the sensor can generate that kind of signal then the cat is at fault. Right?
The sensor after the cat shouldnt read the same as the front sensor if it does then the cat isnt working.
i hate to say it but on a toyota with these symptoms i'd bet a meal that it needs a cat.
- crmeyers
I'm right there with you Steven. Where we eatin' at?
red bones........or adams ribs.........mmmmmmmmmm
tune-up parts cure 80 percent of my cat issues
- a&mauto
Tim, I agree with everything said so far. Also, if there are any other codes, fix them first. Make sure it is going into closed loop. If its not, the cat will not light off. I also compare inlet temp to outlet temp after running it at 2000 rpm's for a couple of minutes. Outlet should be at least 100 degrees hotter. If its the same or cooler, and its in closed loop, and your scope pattern is like the lower one, you probably have a bad cat.
many vehicles with that mileage do need tune ups. if the scope patterns are mirroring each other a tune won't help. i was at a seminar a few weeks ago and there were booths. at the exhaust booth they were pushing a cat flush. any thoughts on this?
Ive never heard of it what is it.
Now steve, you pullin our leg or what? What's a cat flush? Ain't not heard a that yet.
- wbuxton
It's illeagle to flush any animal in Texas. Except a goldfish.
William
Weatherford, TX
817-599-7680
866-744-3887
http://www.phoenixtrans.com
William
Weatherford, TX
817-599-7680
866-744-3887
i've seen this stuff on the shelves of the part store. i'll look into it and post my findings. i'm a firm believer that chemicals like this are a snake oil repiar. like in the movie "the out law josie whales" when he spits chaw juice on the sales man and askes "can it get out tobacco juice"
- crmeyers
Found the cat flush you're talking about:
http://www.youtube.com/watch?v=WofFb_eO ... dded#at=28
Is that cool or is that cool?????
Re: Toyota - Pesky PO420 DTC
That is a cool cat flush. Wait till they get the water bill!
