I don't know if you have seen this or not. Nissan has a problem with there radiator cooler cracking and leaking coolant into the transmission. The repair is to replace transmission & radiator to the tune of about $6000.
Was wondering if there is away to get a customer list to let my customers know of their issue before they have a problem. If the radiator is replaced before it cracks the repair is less then a grand.
The issue affects 2001-2009 Nissan Altima, Xterra, Frontier & Pathfinder models.
If anyone has any ideas please let me know. Thanks
2001-2009 Nissan Radiator/Trans Problem
- tom2
Tom
E.C.A.E
In Sunny San Diego
E.C.A.E
In Sunny San Diego
Re: Nissan radiator/trans problem
If I understand your question correctly, you want to see what customers have one of these Nissans and let them fix it before it breaks. If that is the case you could do history search from F4 and select the YMM and see who has one, contact them and inform them of the impending doom that can be avoided.
Re: 2001-2009 Nissan Radiator/Trans Problem
As stated above, the F4 Find History screen is the way to go. Enter Nissan and most likely one of the model names at a time to check.
- nissan.png (12.49 KiB) Viewed 8452 times
