2004 Ford F150 - 5.4L Cam Phasers
- nickscarcare
I have a customer that has this truck and is looking at having the phasers replaced due to some noise in the engine. He just bought the truck. My question is that is the tools I need for this in the big OTC 6489 set or is there more that I need to do this job.
Re: 2004 f150 5.4 Cam Phasers
Well, that is the set that I have and have used it extensively on setting up the Ford engines. One thing I did and you may also want to get is a Ford Rotunda Tool # 303-448 which is a tool that goes on the front end of the crankshaft when you are setting up the timing chains. I finally broke down and got it as it was a royal pain to keep the crankshaft from turning while doing timing chain work.
Good Luck. hth
Good Luck. hth
- nickscarcare
It also says you need the 303-1046, am I just not seeing that tool in the big ford kit?
Yeah, it's weird. I have the first extra tool and a variant of the second for a Lightning. Guess they don't include them.
Well, I looked and I don't have that one yet and neither is it in the big kit. I guess I'll have to get it. Thanks for the info.nickscarcare wrote:It also says you need the 303-1046, am I just not seeing that tool in the big ford kit?
- nickscarcare
Have you guys done these phasers? Is there a better kit to get than the ones from the dealers? The customer says he seen Comp Cams?? sells an kit for them, supposedly better. I also told him that he will need to only run a oem filter and 5-20 oil, as other filters may not have the right check valves in them. I have not done the phasers on these yet, but have looked into them as I know they are a common problem. Just wondering of there is better longer lasting parts out there for these.
