2003 Jeep Grand Cherokee - Loses Heat
Customer has complained of losing heat. Just turns cold on its own. Originally changed thermostat and backflushed radiator and heater core. Still same problem. Brought back in shop and with a littler more conversation with customer, changed blend door actuator under dash (old one not closing door all the way). Worked for 6 weeks, now back to same problem. Double checked actuator and it is working fine now. Any ideas would be great!!
Re: 03 Jeep G Cherokee Laredo - looses heat
You need to determine flow. I have a set of clear hoses in different sizes I install and watch coolant flow. Sounds like low flow. Once that is determined, next is to establish why. Possibilities: blocked core, blocked passage, worn pump impeller, air pocket, etc.
- Pauls Automotive
Clear hoses....I've never thought of that.....you learn somethiong new every day.
[email protected]
[email protected]
Does it have automatic temp control?
Yup. Go to the hardware store and they'll snip you off a foot of each. Cheap.Pauls Automotive wrote:Clear hoses....I've never thought of that.....you learn somethiong new every day.
