Radiator Coolant Flow
Is there any way to measure the coolant flow through a radiator? If an engine is overheating and after trying to eliminate other possibilities I suspect the rad is at fault, is there a way to prove it without replacing it?
Re: Radiator Coolant Flow
not really the only partial way i look is with a temp gun and half heartily try to find a restriction.
jbadenoch
Post by jbadenoch »
a clear section of rad hose helps. Don't get caught by the water pump impeller seperating from the shaft and not pumping as a result
JBUTITTA
Post by JBUTITTA »
Most radiator shops (like me), if you can find one anymore have flow test machines. I dont typically charge shops for this simple test if they buy radiators from me. Jerry.
The few I found were identified using the temp gun. Once I had the radiator out, I'd pour water in one side and gravity would hardly get it out the other. That was my confirmation. Not very scientific, but effective. :oops:
Know anyone on a local fire department? Call them and see if they will happen to stop by with an Engine. Tell them you heard about something called a "thermal imaging camera". Then kinda hint like "hey I got an idea! Lets go look at this radiator" You will be able to see it with that! :wink:
If you were in "my parts" i'd do it for you.
http://www.marylandenergyauditor.com/ho ... al-imaging
To me its kinda like a process of elimination. Fan or fan clutch works ok. t stat works ok. is outlet temp on rad different then inlet? Also a must is the combustion gas test. Overheating vehicle are sometimes the hardes to figure out.
JBUTITTA wrote:Most radiator shops (like me), if you can find one anymore have flow test machines. I dont typically charge shops for this simple test if they buy radiators from me. Jerry.
Flow Test Machine. What does that consist of.
Don't laugh, I am revealing my ignorance, I know.
JBUTITTA
Post by JBUTITTA »
Im not compruter savy enough to post a pix, but if you go to barbeecompany.com/catalog.pdf and on page 2 they have their RATE-O-FLOW machine. Basically it is a high volume pump with a gallon per minute meter. As a rule of thumb, a 20 in wide radiator with 1 row of 1in tubes(alluminum) , or 2 row 1 1/4 in thick core (copper/brass), should flow approx 20gpm. jerry
The radiator shops I've visited had big scary machines like this.
Big Scary
Big Scary
JBUTITTA
Post by JBUTITTA »
Ric, that would be a boilout tank for cleaning. Hot caustic soda is pretty nasty stuff, but works great on copper/brass radiators. Just dont try to clean aluminum radiators with it. :oops:
A bit old school here but the way i test for a restriction is letting it run until the temp reads about 1/3 and running my hand across the radiator. I can feel the cold spots this way. I haven't run into a restricted radiator in years. The more i think about it i've run into impeller issues more than restricted radiators.
