2002 Lexus RX300 - Yaw Rate Sensor
Anyone know where the Yaw rate sensor is on an '02 RX 300? Mitchell says it is at the left rear--SURE!!!
Michael
Princeton Auto Service Center
- liljoe
Re: Yaw Rate Sensor on '02 RX300
This is the best I could find, I have never looked for one yet. Hope this helps...
- liljoe
Found this too.....
- liljoe
Here is what it should look like....
Re: 2002 Lexus RX300 - Yaw Rate Sensor
I have the same pic as shown above. I've usually found these under the center console between the seats bolted to the floor. Has to be on centerline with the vehicle. The pic shows it more aft, but usually it's equidistant from the all the wheels.
Thanks guys. Looking this morning under the rear seat. I'll find it. Just needed some indications.
Thanks again.
Thanks again.
Michael
- a&mauto
Michael,
We have seen some different issues with these on Lexus. Most of the time, we recalibrate them, and the code goes away. These technically should be re-calibrated after an alignment. Let me know if this helps.
I did locate the sensor between the rear seat and the trunk. A pain to get to. I recalibrated the sensor previous to accessing. Code was still present. I removed the sensor, checked wires, connections and resistances and all checked good. Re-installed the sensor and the code was gone. I can only assume the connection at the sensor was compromised.
Thanks for all of your help.
Michael
