Lube Sticker Pro Settings & More...
Oil change sticker software & printers
MRISICH
200 Club: Major Contributor
Re: Lube Sticker Pro Settings & More...
Post by MRISICH »
Lube Sticker Pro; now prints key tags on the same printer to give your customer a professional experience at your shop!
Below are three layouts currently offered in the software!
Lube Sticker Pro - Key Tag 1
75 X 2 keytag.jpg (8.3 KiB) Viewed 28298 times
Lube Sticker Pro - Key Tag 2
125 X 225 Keytag.png (13.65 KiB) Viewed 28298 times
Lube Sticker Pro - Key Tag 3
125 X 325 Keytag.jpg (14.14 KiB) Viewed 28298 times
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Post by MRISICH »
The Next Release of Lube Sticker Pro; to include common reset instructions on vehicles.
Step 1: Click the button
Lube Sticker Pro - Reset Oil Sticker Instructions
Step 2: Review and or Print Details
Lube Sticker Pro - Reset Instructions Details
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
Gerald Martin
Post by Gerald Martin »
Mike, it just keeps getting better, doesn't it?
Gerald
MRISICH
Post by MRISICH »
Thanks Gerald; As you know, anything we can do to help...
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
a&mauto
Post by a&mauto »
We are using the Dymo 450 Turbo label writer. Everything has worked great! We are using the stick-on labels with no problems. How do we re order the exact same labels?
Adam Jadovitz
A & M Automotive
Lake Elsinore, CA
951-245-1562
MRISICH
Post by MRISICH »
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
a&mauto
Post by a&mauto »
Thank You for your help.
Adam Jadovitz
A & M Automotive
Lake Elsinore, CA
951-245-1562
MRISICH
Post by MRISICH »
Lube Sticker Pro just got better! (SE Users only)
Now we have added the ability to reschedule and auto add vehicle recommendations when using any canned job in your management system.
Simply click on the settings then automation, then click the Advanced Scheduling button
Lube Sticker Pro - Advanced Button
The list screen will display next, initial load will be empty.
Lube Sticker Pro - Advanced Schedule
Now you simple can apply your settings for additional appointments and/or vehicle recommendations
Lube Sticker Pro - Advance Schedule
Now you will be adding valuable content on every print event inside of Lube Sticker Pro!
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Post by MRISICH »
This is a great value added feature; If you have vehicle recommendations when you print out your customers invoice and you are using advanced coupons tied to service categories in Report Pro. This will now automate that process of making sure your invoices are customized for each vehicle.
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
ARS
Post by ARS »
We are using the Zebra TLP 2824 Plus printer for our labels. We got this printer free as a promotion when we changed over from new filters. The promo also came with Labels. They are the static cling ones. We are having major problems with them falling down off of the windows. Customers are calling & asking when their next oil change is... plus we are losing the free advertising that goes with the sticker. Thankfully the lube sticker pro has the next oil change info on their ticket & on out computer. But does anyone have any great ideas on how to get those static clings to stick. Or where we can get labels that will stay!!! Thanks, ARS
I don't recommend getting the ones that stick with the dymo printer I hate removing them and they fade fast. I clean the windshield before putting on a static cling ant they remain legible and stay on the duration.
MRISICH
Post by MRISICH »
It is a catch 22; one sticks "too well" the other "not enough". The latest DYMO labels have less adhesive; check out http://wwww.mitchell1supplies.com for more information.
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
alloutrepair
Post by alloutrepair »
I wish I could just run with these on a standard printer!!!
Why does it have to be so difficult?!?!
So many options, so many opinions... and if I spend the money & never use it... well that's just GREAT!!!
THANKS!
~Jennifer~
Jeff @ Able Auto
Post by Jeff @ Able Auto »
I have yet to buy the printer. The key is to still mark them to print so it loads the next appointment.
MRISICH
Post by MRISICH »
Hello,
In case it is helpful, here is the approved list of printers that will work with Lube Sticker Pro immediately following program installation and setup. This list is based on purchase from an approved supplier or directly from the manufacturer. Printers cost about $100.
1. Brother QL 580N
2. Dymo Labelwriter 450
3. Dymo Labelwriter 450 Turbo
4. Zebra TLP-2824
5. Zebra TLP-2824 Plus
6. TSC TTP-225
7. TECLABEL TT040-50
Here are some printers that we have been successful at creating custom label templates for:
1. GODEX RT200
2. Dymo Labelwriter 450 Twin Turbo
3. Cognitive DLXi DBT24-2085-G1s
4. Cobra Striker T-3000
• As general rule of thumb, the following will work but may require a Custom Label be created.
o Dymo printer models that are compatible with their Labelwriter software
o Brother printer models that are compatible with their P-Touch software
o Static Cling printer models that are Windows 7 or better compatible and accept Zebra Printer Language (ZPL) or run ZPL Emulation. If any doubt about a static cling printer, the shop needs to call the company that supplied them the printer to find this info out.
Please let me know if I can be of further help.
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
Return to “Lube Sticker Pro”
