Error trying to order parts on 7.3.7
I'm on 7.3.7. When trying to order parts in a sub estimate I get this error. Then the program stops working for awhile then the order screen will appear.
- 1.jpg (219.57 KiB) Viewed 8151 times
Re: Error trying to order parts on 7.3.7
This will likely need assistance from support, but what vendor/protocol are you using when the error occurs?
Try this: Copy and paste the items to another revision. Restart the program. Try again - see if works.
Gerald
Gerald
I get something like that at times also, been to busy to figure out what triggers it.
Sorry all,
I'm a couple of days behind. You can safely ignore this message and continue working. We are releasing a 7.3.8 patch in the near future to address this, but you will see this in Parts Ordering from Revisions periodically until updated.
- Johnny5
As Dan says, you can ignore the message, it does not harm any data. Click on IGNORE. A fix is being brewed right now.
Did i hear BREW? I could use one!
Thanks for letting us know. Not that i was worried....
- Johnny5
I have some frosty cold Shiner Bocks in the fridge at home...Rich wrote:Did i hear BREW? I could use one!
If Cali wasn't so far away...I will be in Tims neck of the woods next weekend.Johnny5 wrote:I have some frosty cold Shiner Bocks in the fridge at home...Rich wrote:Did i hear BREW? I could use one!
Hey what's all this now?Rich wrote:Johnny5 wrote:Rich wrote:Did i hear BREW? I could use one!
- rhillig
Another error with the parts system. I notice that every time there is an update - it reverts the Mighty catalog to a previous version. I have to go around and manually re-install the Mighty catalog install on each computer.
Thanks for reporting this. It would certainly appear we're installing an older .dll than what is available. Making a record to get that fixed for our next major version/installer.rhillig wrote:Another error with the parts system. I notice that every time there is an update - it reverts the Mighty catalog to a previous version. I have to go around and manually re-install the Mighty catalog install on each computer.
