Error trying to order parts on 7.3.7
I'm on 7.3.7. When trying to order parts in a sub estimate I get this error. Then the program stops working for awhile then the order screen will appear.
dandsautoandtruck
Re: Error trying to order parts on 7.3.7
Post by dandsautoandtruck »
Ditto.
This will likely need assistance from support, but what vendor/protocol are you using when the error occurs?
Gerald Martin
Post by Gerald Martin »
Try this: Copy and paste the items to another revision. Restart the program. Try again - see if works.
Gerald
I get something like that at times also, been to busy to figure out what triggers it.
Sorry all,
I'm a couple of days behind. You can safely ignore this message and continue working. We are releasing a 7.3.8 patch in the near future to address this, but you will see this in Parts Ordering from Revisions periodically until updated.
As Dan says, you can ignore the message, it does not harm any data. Click on IGNORE. A fix is being brewed right now.
Did i hear BREW? I could use one!
Thanks for letting us know. Not that i was worried.... :shock:
Rich wrote:Did i hear BREW? I could use one!
I have some frosty cold Shiner Bocks in the fridge at home...
If Cali wasn't so far away...I will be in Tims neck of the woods next weekend. :wink:
Hey what's all this now? :mrgreen:
rhillig
Post by rhillig »
Another error with the parts system. I notice that every time there is an update - it reverts the Mighty catalog to a previous version. I have to go around and manually re-install the Mighty catalog install on each computer.
rhillig wrote:Another error with the parts system. I notice that every time there is an update - it reverts the Mighty catalog to a previous version. I have to go around and manually re-install the Mighty catalog install on each computer.
Thanks for reporting this. It would certainly appear we're installing an older .dll than what is available. Making a record to get that fixed for our next major version/installer.
