Is there a quick way to visualize the tech's efficiency on a per-work-order basis? For instance, the order screen displays total labor hrs. Where can we see a total of actual hrs (if the techs are clocking in and out on labor items using Mobile Manager?)
Maybe the answer is hiding in plain sight.
Gerald
Order Hrs vs Actual Hrs
Re: Order Hrs vs Actual Hrs
Anyone?
- Pauls Automotive
- 1000 Club: Interstellar
I don't know of any quick way within Mitchell short of manually making the calculations. I ended up using a third party program that is a time clock that the guys sign in for the day but also per job that integrates with Mitchell and gives me all those numbers. It is called Labor Profit Management.. If that is of any help.
That data is not being written back to storage in SE; if any reporting was to be available it would be in their ReportPro portfolio.Gerald Martin wrote:Is there a quick way to visualize the tech's efficiency on a per-work-order basis? For instance, the order screen displays total labor hrs. Where can we see a total of actual hrs (if the techs are clocking in and out on labor items using Mobile Manager?)
Gerald
Since MM Pro / time clock is referenced, I am moving this to their topic area.
- Auto Repair Coach
Currently, without using the Labor Profit Management Software mentioned above, there is no way in Mobile Manager to automatically calculate tech efficiencies. No data is written since there is no place to put it at this time. No data, no reports. (Example. Where would tech punch in and out for the day go?)
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
