Deleting A R/O
Deleting A R/O
The problem I am having is that if I create 2 R/O's for the same job, I can accumulate several leftover jobs with a zero balance in the "'Work In Progress" screen. Can I delete 1 of them? Of so, how?
I looked for info about this in the help section of Manager and on this forum but couldn't find what I am needing. Perhaps I missed it.
1000 Club: Interstellar
Re: Deleting A R/O
Post by Pauls Automotive »
I am not sure if I understand what you want but what I am getting is you want to just delete the duplicate RO's. If so then open the RO you want to delete and click "edit" in the left upper screen and click "remove Order". Repeat for all un wanted RO's. There is no mass RO delete option.
[email protected]
Re: Deleting A R/O
Pauls Automotive wrote:I am not sure if I understand what you want but what I am getting is you want to just delete the duplicate RO's. If so then open the RO you want to delete and click "edit" in the left upper screen and click "remove Order". Repeat for all un wanted RO's. There is no mass RO delete option.
Thanks Paul. That should work.
Return to “Tips + Ideas”
