New Workflow Manager - Suggestions
We were having a meeting today about Workflow Manager and how we are almost ready to replace our whiteboard with it. Some interesting ideas came up....
1. We have a lot of statuses. Even after paring down we still have 2 full screen widths. Someone suggested that unused statuses auto-hide. Note we'd change status on the desktop or tablet. Another suggestion was to have the rows repeat below the first.
2. We don't assign technicians on whole orders, just at the job level. Many reasons for this; too numerous to get into here. Because we don't need to see technicians in WM, hiding them leaves a lot of unused space below them main rows. Couple this with the fact that after a certain number the tiles minimize while all this space is available. The suggestion is to let the tiles grow without minimization to a user defined quantity. That way we can tailor the layout to the individual.
Great work with WM. Keep it coming!!!
- Auto Repair Coach
Re: New Workflow Manager - Suggestions
Hey Ric,
Some good ideas here that I will immediately put in for development to look at.
Thanks
Thanks
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
Thanks JB.
Two other ideas came up during that meeting that I forgot to mention. Maybe the developers will like....
1. Allow for check box marking within WM.
2. Allow for color naming/labeling.
We are temporarily disabling our whiteboard and running WM solely so we can shake out all the needs we will find. Change is scary sometimes but progress is good.
We are experimenting with colors on the tiles. One thought was to reflect that color change onto the tablets so it is easy to let the techs in on the coding. Change a tile to yellow, the corresponding item in WIP on the tablet also changes.
- Auto Repair Coach
Got it. Another good idea.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
I'm fairly sure I've asked this before but I can't find it. Any thought of putting the hat # on the tile? Doing so would allow techs to associate numbered keys with jobs by simply looking at the WorkFlow screen. Right now we have to open an order on a tablet.
- Auto Repair Coach
Ric,
Double left click on the tile to open the info window and you will see the fleet number to the right of the VIN and Tag. Does that work?
See attached.
See attached.
- Fleet#.JPG (37.5 KiB) Viewed 22597 times
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
That's not the Hat#. We are looking for Hat# visible on the tile without any interaction.
Back in the day and maybe today still at some shops there was a vehicle identification/association system called a hat. We no longer use the actual hats but still associate a key tag with this number/vehicle. There's a specific place for this number in Manager.
Our goal is to place a large screen above the keys where my whiteboard once stood so that anyone can easily associate a key number with a customer car.
- Pauls Automotive
- 1000 Club: Interstellar
I agree with Ric. The Hat# being visible on the tablet would be very helpful. We use it everyday!
[email protected]
[email protected]
Thanks Paul. My request is actually to have it visible on the tile in WorkFlow Manager, but showing it on the tablets on the WIP screen without opening an order is a great idea too.Pauls Automotive wrote:I agree with Ric. The Hat# being visible on the tablet would be very helpful. We use it everyday!
- Auto Repair Coach
Doof! Sorry. Since we current do not support the Hat# on the tablet or WorkFlow, my default use was the Unit number.
I'll put in the request.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
I keep the Work Flow Manager open all day. It would be very helpful to have it with it's own button to open it. And open separate window like Message Manager.
***It closes when Report Pro is closed.
Wanda
Motorcar Alternatives
603-622-6434 x204
603-622-6434 x204
- Pauls Automotive
Hi Wanda. You can do that today. Go into report Pro and click the "Tools" tab and on the left you will see a "Workflow Manager" icon. If you click it workflow manager will open in it own window and be independant of report pro. You never have to worry about it closing out.
[email protected]
[email protected]
That is how I am using it. However if you close the Report window you have to go through all the steps to open it again. I feel it would be helpful if it was an independent window.
Wanda
603-622-6434 x204
603-622-6434 x204
Yes. Workflow Manager does have a separate window, but it's not independent from Report Pro. Close report Pro and *poof*, the window is gone. The thought is to have it's own button (read launcher) similar to Report Pro, Message Manager, Lube Sticker Pro, etc.
- Pauls Automotive
My mistake. Sorry I didn'y quite get what you meant.Wanda wrote:That is how I am using it. However if you close the Report window you have to go through all the steps to open it again. I feel it would be helpful if it was an independent window.
[email protected]
[email protected]
- Auto Repair Coach
I will enter a request to make Workflow Manager "live on it's own" and have it's own app button on the launcher.
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
I found a workaround for those who have a ton of statuses. Simply take the independent version of WM and the Report Pro version and place them on the same screen, split top and bottom. This allows for 28 statuses to be displayed on one screen, up to 4 tiles per status.ricmorin wrote: ↑Tue Oct 22, 2019 2:13 pmWe were having a meeting today about Workflow Manager and how we are almost ready to replace our whiteboard with it. Some interesting ideas came up....
This completes our transition from the whiteboard, which has been gone for months.
Still waiting on being able to see Special Orders in WM. That would be nice. Also would like to see the HAT number on the tile, along with the ability to check off boxes within the tile. Overall, this display is a far cry from the old whiteboard.
Please share how you are using Workflow Manager. If you aren't using it, share how you control work through your shop.
- Auto Repair Coach
I have requested this be addressed during the "clean up phase".
John Burkhauser
BOLT ON TECHNOLOGY
BOLT ON TECHNOLOGY
Thanks JB. We love the new WM program.
